1. leht 2-st
Releekarbid erinevatel Omegatel(mis relee on mis)
Postitatud: 31 Okt 2009 20:54
Postitas Q-tok
X20XEV ja X20XE 4 silindriline bensiin
Note: section inside dashed line changes with aircon as per alternative view at top left
Position Relay Code Colour Comments 1 K12 Brown -
2 K97 Black Headlamp Washers
3 - Violet Test Connector
4 K67 Dark Blue -
5 K60 Green With Aircon
6 K87 Green With Aircon
- - Carrier plug - Without Aircon
7 K51 Black Without Aircon
K26 Grey With Aircon
8a F42 Black With Aircon
F51 Red Without Aircon
8b F52 Green With Aircon
F49 Black Without Aircon
10 K43 Violet -
12a F39 Green Headlamp Washers
16 - Black Carrier Plug With Aircon
17 K52 Brown -
19 K49 Green -
20 K44 Violet -
29a F42 Black -
29b F49 Black -
Re: Releekarbid
Postitatud: 31 Okt 2009 20:58
Postitas Q-tok
X25XE ja X30XE V6 bensiin
Position Relay Code Colour Comments 1 K12 Brown Secondary Air Injection Relay
3 - Violet Test Connector - without aircon
3 K22 White Aircon coolant pump relay
4 K67 Dark Blue Cooling fan Relay
5 K60 Green Aircon compressor relay
6 K87 Green Aux cooling fan relay - with aircon
7 K26 Grey Blower relay - with aircon
8a F50 Red Without Aircon
9 K8 Yellow Windscreen wiper relay
10 K43 Violet Fuel Injectors relay
16 - Black Carrier Plug - With Aircon
17 K52 Brown Blower relay
18a F50 Red -
18b F52 Green -
19 K48 Orange Blower relay
20 K44 Violet Fuel Pump relay
27 - Violet Blower Test Connector - aircon only
28a F40 Green -
29a F42 Black -
29b F49 Black -
Re: Releekarbid
Postitatud: 31 Okt 2009 21:01
Postitas Q-tok
Relay Code
F39 Fuse
F40 Fuse
F42 Fuse
F50 Fuse
F52 Fuse
K8 Interval Wiper Windscreen
K22 Pump, coolant
K26 Radiator Fan
K28 Radiator Fan
K44 Fuel Pump
K52 Radiator Fan
K60 Compressor - Aircon
K67 Radiator Fan
K87 Radiator Fan
K97 Time delay, washer pump, headlamps
K114 Engine (Main Relay)
Re: Releekarbid
Postitatud: 31 Okt 2009 21:04
Postitas Q-tok
X20DTH 4 silindriline diisel
Position Relay Code Colour Comments 1 K53 Brown -
3 K52 Brown -
4 K8 Yellow -
5 K34 Green -
6 K26 Black -
7 K67 Dark Blue -
K74 Orange With Aircon
8 K49 Green -
9 K114 Black -
10 - - Carrier Plug
16 - - Test Connector Blowers
17a F42 Black -
17b F34 Black -
18a F51 Red -
19a F59 Yellow -
28 K60 Green With Aircon
30/40 K76 Black -
Re: Releekarbid
Postitatud: 31 Okt 2009 21:06
Postitas Q-tok
U25DT ja X25DT 6 silindriline diisel
Position Relay Code Colour Comments 1 - Violet Test Connector
K96 Grey
3 K22 White -
4 K8 Yellow -
5 K127 Green Without Aircon
6 K26 Grey Without Aircon
7 K67 Green Without Aircon
K51 Black With Aircon
8 K48 Orange Aircon only
8a F50 Red -
9 K80 Green -
10 K16 Black -
17 K52 Brown -
18a F42 Black -
F50 Blue -
18b F52 Black Without Aircon
19a F36 Green -
20 K13 Green -
27a F55 Yellow -
28a F42 Black -
28b F52 Black -
30 K25 -
40 K17 -
Re: Releekarbid erinevatel Omegatel(mis relee on mis)
Postitatud: 15 Juul 2010 19:03
X20XEV kapoti alused releed/kaitsmed,koos AC´ga.Andmed autodatast.
1.Variable air induction R.(relay)-Lisaõhu pumba R.
2.Headlamp washer pump delay R-Esitulede pesuri R.
3.Engine coolant blower motor R. I -Jahutusventilaatori R.
4.AC clutch R.-Konditsioneeri siduri R.
5.Air conditioning condenser blower motor R.
6.Engine coolant blower motor R. II
7.Engine control module R.
8.Engine coolant blower motor R. III
9.Relay box cooling fan R.-Releekarbi(aju)jahutus
10.Fuel pump R.-Bensiini pumba R.
11.ECM-aju
F1.Headlamp washer pump
F2.Engine coolant blower motor
F3.Secondary air induction
F4.Engine coolant blower motor
F5.Relay box cooling fan
Postitatud: 02 Mai 2011 16:53
Postitas paikas
ja ikka ei kleia ma kuskilt tulede releed...
Postitatud: 02 Mai 2011 17:33
Postitas opelist
paikas kirjutas:ja ikka ei kleia ma kuskilt tulede releed...
Kaugtulede relee on rooli all, päevasõidutulede relee käib kõrvalistuja jalgadest paremale katte taha.
Postitatud: 02 Mai 2011 19:27
Postitas paikas
ma otsin tulede üldist releed, või on opeli insenerid veel ühe tähtsa asja unustanud?
Postitatud: 02 Mai 2011 20:46
Postitas Omega Sport Packet
fixuses oli automaatt relee mingi 18 euri.Mis asi endast kujutab või kas auto maha põletab ei oska kommenteerida:)
Postitatud: 06 Mai 2011 19:09
paikas kirjutas:ma otsin tulede üldist releed, või on opeli insenerid veel ühe tähtsa asja unustanud?
Mingi "kopsik"on rooli pool armatuuri all peidus,seal hulk siniseid/rohelisi/halli jne.värvi releesid+1.suitsupaki suurune karp-ehk see tulede üldine relee.Uuri oma silmaga järgi.
Re: Releekarbid
Postitatud: 11 Okt 2011 13:00
Postitas op
Q-tok kirjutas:U25DT ja X25DT 6 silindriline diisel
K96 Grey
3 K22 White -
4 K8 Yellow -
8a F50 Red -
9 K80 Green -
10 K16 Black -
17 K52 Brown -
18a F42 Black -
F50 Blue -
19a F36 Green -
20 K13 Green -
27a F55 Yellow -
28a F42 Black -
28b F52 Black -
30 K25 -
40 K17 -
Et keegi selle Eesti keelde ka tõlgiks ,Värvidest saan aru aga mille omad need on miks neil ainult kriipsud taga on.
Re: Releekarbid
Postitatud: 18 Veebr 2013 22:44
Q-tok kirjutas:X25XE ja X30XE V6 bensiin
Relay Code
F39 Fuse
F40 Fuse
F42 Fuse
F50 Fuse
F52 Fuse
K22 Pump, coolant
K26 Radiator Fan
K28 Radiator Fan
K44 Fuel Pump
K52 Radiator Fan
K67 Radiator Fan
K87 Radiator Fan
Selle tabeli järgi küll ei saa mitte halligi aru milline see udukate relee on.
Re: Releekarbid
Postitatud: 18 Veebr 2013 23:05
Postitas zajets
Tomzz kirjutas:Q-tok kirjutas:X25XE ja X30XE V6 bensiin
Relay Code
F39 Fuse
F40 Fuse
F42 Fuse
F50 Fuse
F52 Fuse
K22 Pump, coolant
K26 Radiator Fan
K28 Radiator Fan
K44 Fuel Pump
K52 Radiator Fan
K67 Radiator Fan
K87 Radiator Fan
Autodatas ei näita et udutuledel mingi eraldi relee oleks.
Ainult kaitse F16 on esimesed udutuled.
Re: Releekarbid
Postitatud: 19 Veebr 2013 10:30
Tomzz kirjutas:Selle tabeli järgi küll ei saa mitte halligi aru milline see udukate relee on.
Kas udutuledel eraldi relee on,seda täpselt ei tea.Pm.peaks ju olema,voolutarve on korralik(pm.sama mis kaugtuledel ju).Samas armatuuri all(mitte seal olevas kaitsmete/releede karbis)on veel peidus kena hulk karbikesi(pole nii väga uurinud aga näevad küll releede moodi välja).
Kindla vaste saab õigest el.skeemist.
