Opel Omega B elektriskeemid
reims86
Re: Opel Omega B elektriskeemid
Postitus Postitas reims86 »
Kuidas ühendada kompuutri kaableid
Two connector pin out:
Yellow connector:
Pin 1 - Red - To F12 (20A)
Pin 2 - Brown - To Chassis (0V)
Pin 3 - Blue/White stripe - Outside temp sensor
Pin 4 - Blue - Outside temp sensor
Pin 5 - Black - To F15 (15A)
Pin 6 - Grey/Green stripe - To F26 (10A)
Pin 7 - Grey/Yellow stripe - Instrument Illumination (dimmer controled)
Pin 8 - Red/Grey Stripe - Radio (aerial power feed i.e. Radio on indication)
Pin 9 - Brown/White Stripe - Radio Serial Interface
Pin10 - Brown/White Stripe - Radio Serial Interface
Pin11 - Brown/White Stripe - Radio Serial Interface
Pin12 - Blue/red stripe - Speed signal (from ABS controller)
Pin13 - NC
Pin14 - Brown/White Stripe - To pin 8 of diag connector (to support programming)
Pin15 - Black/Yellow stripe - To check control
Pin16 - Black - To F2 (15A)
Pin17 - White/Green stripe - To check control
Pin18 - Black/Yellow stripe - To check control
Pin19 - Yellow/Red stripe - To brake pad wear sensors
Pin20 - NC
Pin21 - NC
Pin22 - NC
Pin23 - Grey - To Auto transmission
Pin24 - NC
Pin25 - NC
Pin26 - NC
Black Connector
Pin 1 - Brown/Blue stripe - To fuel pump relay (i.e. engine running)
Pin 2 - NC
Pin 3 - Brown/Blue stripe - Coolant level sensor
Pin 4 - Brown - To chassis (0V)
Pin 5 - Brown/White Stripe - Computer stalk buttons
Pin 6 - Brown/Red Stripe - Computer stalk buttons
Pin 7 - NC
Pin 8 - Blue/Black Stripe - Fuel level sender
Pin 9 - Black/Brown Stripe - ECU signal
Pin 10 - Brown/Yellow Stripe - Washer Level sensor
Pin 11 - Brown/Grey Stripe - Oil level sensor
Pin 12 - NC
Grey connector info, in the brackets is the equivalent earlier MID pin info (Y=Yellow con and B=Black con)
Pin1(Y2) - Brown - To Chassis (0V)
Pin2(Y3) - Blue/White stripe - Outside temp sensor
Pin3(Y4)- Blue - Outside temp sensor
Pin4(Y5) - Black - To F15 (15A)
Pin5(Y1) - Red - To F12 (20A)
Pin6 - Green - RPM signal
Pin7(Y7) - Grey/Yellow stripe - Instrument Illumination (dimmer controled)
Pin8(Y8) - Red/Grey(white) Stripe - Radio (aerial power feed i.e. Radio on indication)
Pin9(Y9) - Brown/White Stripe - Radio Serial Interface
Pin10(Y10) - Brown/White Stripe - Radio Serial Interface
Pin11(Y11) - Brown/White Stripe - Radio Serial Interface
Pin12(B8) - Blue/Black Stripe - Fuel level sender
Pin13(B11) - Brown/Grey Stripe - Oil level sensor
Pin14(Y14) - Brown/White Stripe - To pin 8 of diag connector (to support programming)
Pin15(Y15) - Black/Yellow stripe - To check control
Pin16(Y16) - Black - To F2 (15A)
Pin17(Y17) - White/Green stripe - To check control
Pin18(Y18) - Black/Yellow stripe - To check control
Pin19(Y19) - Yellow/Red stripe - To brake pad wear sensors
Pin20 - NC
Pin21(Y23) - Grey - To Auto transmission
Pin22(B10) - Brown/Yellow Stripe - Washer Level sensor
Pin23(B5) - Brown/White Stripe - Computer stalk buttons
Pin24(B6) - Brown/Red Stripe - Computer stalk buttons
Pin25 - NC
Pin26(Y12) - Blue/red stripe - Speed signal (from ABS controller)
Pin27(B9) - Black/Brown Stripe - ECU signal
Pin28(B3) - Brown/Blue stripe - Coolant level sensor
Pin29 - Black/Violet Stripe - To Hid lighting
Pin30 - To Diesel fuel pump (X20DTH only)
creative2
Postitus Postitas creative2 »
Tere! Oleks huvi teada saada kuidas ma peaks elektriskeeme lugema , tarvis oleks käigukasti elektijuhtmed üle vaadata! Ehk oskab keegi nõustada
On Sul skeem olemas?
creative2
autodatast saan jap , aga ise ei oska sealt miskit välja lugeda peale juhtmevärvuste , arvatavasti on juhtmepuntras mingid juhtmed ära hõõrunud!
creative2
Kui ma ausalt ütlen siis sellekohapealt olen täielikult 0:D ei saa minust elektrikut
Kalmer1102
Postitus Postitas Kalmer1102 »
Tere!
Kas 2003a. Omega elektri skeeme ka kellegil leidub?
Oleks vaja just mootori aju ja sealt autosse skeeme.
Kui keegi on 3.0 150kw diisel mootori enda omega peale sobitanud, siis võib mulle sellest rääkida! :D
2.5 dti 110kw
Tänan!
elektri skeemide jaoks tõmba opel TIS. saad kõik asjad kätte.
142kw läheb peale nagu nalja 150, on tiba teine teema juba.
Kalmer1102
Olemas!
Tänan info eest! :D
Hašš
Postitus Postitas Hašš »
Tere.
Kus kohast võiks leida auto poolse elektriskeemi? Oleks vaja teada milline pin on kapotialuses pistikus mootori temperatuur spidoka blokis.
Mootoriks oli algselt 2.0 ohc ja nüüd sai peale pandud c20let calibra pealt aga ei saa kuidagi mootori tempi näitama.
Ette tänades.
